lynnbs
Jun 22, 2022Guide
Nighthawk X6S AC3000 Tri Band WiFi Router ...internet keeps timing out
Hi, I'm a newbie here, so be kind! 😉 OK, after two weeks of thinking it was my PC, I think I've narrowed down the problem to my router. Here are the facts: 1) just realized today that my husban...
- Jun 22, 2022
Try auto detect on the ipv6.
The .88 firmware version has some dns issues that we've notice.
For many people, using ipv6 fixed it.
others downgraded to an earlier version.
Jun 22, 2022Guru - Experienced User
What modem/gateway is it connected to?
What firmware is on the router?
do you have IPv6 enabled? If not, enable it and test.
lynnbs
Jun 22, 2022Guide
How can I tell what firmware or if IPV6?
Arris TM1602G Modem
- FURRYe38Jun 22, 2022Guru - Experienced User
Log into the routers web page at 192.168.1.1.
IPv6 could be enabled and thats ok. That's also on the routers web page under Advanced tab/Advanced/IPv6.
Please give feedback to the other questions as well.
Try a different browser.
Be sure to clear out ALL browser caches as well. Then close and reopen the browser then try web sites.
- lynnbsJun 22, 2022Guide
OK...here's a screenshot of IPv6. Doesn't look enabled, but not sure which option to choose.
There are 16 devices attached to the router, most I recognize but some have me confused:
- 2.4 G wlan0 is attached 3 times with different IP addresses
- My laptop is attached twice with different IP addresses
- No idea what ESP BCB453 is, tried a google search on it, but no idea.
Firmware Version is V1.4.3.88_1.3.50
Re. Channels
- For 2.4G it is Auto (2)
- For 5 G it is 36 + 40 + 44(P) + 48
- For 5 G -2 it is 149 + 153(P) + 157 + 161
Is Armor Circle the Shield with the capital A in the middle? If so, it is not enabled.
Also tried Microsoft Edge as well as chrome just now. Cleared browsing history and cache of both...made no difference.
- plemansJun 22, 2022Guru - Experienced User
- michaelkenwardJun 22, 2022Guru - Experienced User
lynnbs wrote:
Arris TM1602G Modem
This:
ARRIS Consumer Care - TM1602G/NA-8
Simple modem. No integrated router to muddy the waters.
