lynnbs
Jun 22, 2022Guide
Nighthawk X6S AC3000 Tri Band WiFi Router ...internet keeps timing out
Hi, I'm a newbie here, so be kind! 😉 OK, after two weeks of thinking it was my PC, I think I've narrowed down the problem to my router. Here are the facts: 1) just realized today that my husban...
- Jun 22, 2022
Try auto detect on the ipv6.
The .88 firmware version has some dns issues that we've notice.
For many people, using ipv6 fixed it.
others downgraded to an earlier version.
Jun 22, 2022Guru - Experienced User
What devices do you have all connected?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor, Circle, Traffic Meter enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
lynnbs
Jun 22, 2022Guide
Hi Furrye38
OK, so I am uncertain where to find info on firmware,devices and channels, but Modem is Arris TM1602G. I know I've seen a site where I should be able to find all this info, but I just need a wee bit of direction to get there.
I have two wifi neighbors nearby.
I just performed the reset that you recommended, following the steps in order and for appropriate time. When I got back on I tested several sites and was feeling very optimistic in that they were coming right up and quite quickly, to boot!
I clicked over to this page to tell you that, and don't you know I received the page again! see attached.
- plemansJun 22, 2022Guru - Experienced User
You can enable ipv6 through the browser.
https://kb.netgear.com/24006/How-do-I-set-up-an-IPv6-Internet-connection-on-my-Nighthawk-router
