Rick01's avatar
Rick01
Nighthawk X6S AC3600 model R7960P need to connect to older cable modem router with IP ad 192.168.0.1
I have an older cable modem router Netgear C6300BD. The IP address of the cable modem is 192.168.0.1. Alll devices are connected on this IP range (vs 192.168.1.1).
I want to add the new Nighthawk router X6S AC3600 R7960P as a wired access point to the existing network. I know the new router is much better than the older cable modem router.
I do not want to change the IP address to the 192.168.1.1 range since there are quite a few wired devices with static IP addresses and I don't want to go to the trouble of changing all of those. Lazy...I know...
This is an experiment in preparation for adding a wired access point to a pole barn at a different property.
I am not quite sure how to go about this. I believe the problem will be the 192.168.0.1 gateway address...
Thanks
  • > I do not want to change the IP address to the 192.168.1.1 range since
    > want to go to the trouble of changing all of those. [...]
       When you say "static", do you mean _really_ static, that is,
    configured on the device itself, or only reserved (dynamic), that is,
    configured on the (DHCP server on the) router (C6300BD, router section)?
    (Either way should give similarly reliable/fixed addresses, but it's
    nice to know what's actually happening.  Using static addresses requires
    more care in the configuration of the DHCP server.)
       Fear not.  Configuring an R7960P (or most any other router) as a
    wireless access point will make it too stupid to cause this kind of
    trouble.  Visit http://netgear.com/support , put in your model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for "Set
    Up the Router as a WiFi Access Point".
       With the default option, "Get dynamically from existing router", your
    R7960P-as-WAP will get its (LAN) IP address from your main router
    (C6300BD), just like your other DHCP clients.  And that means that it
    will have an address in the "192.168.0.*" subnet (just like the other
    devices on your LAN).  (And if you chose the other option, then _you_
    would need to configure the R7960P-as-WAP with a (static, LAN) IP
    address in that same subnet.)
       The R7960P-as-WAP will also be too stupid to act as (or care about)
    any gateway, or DHCP server, or much else; all those tasks will be
    handled by your main router (C6300BD).
       A wireless access point is all-LAN, and uses the same IP subnet as
    everything else on your existing LAN.   It should be mostly harmless.
    What could go wrong?  (Only one way to find out.)
    • Rick01's avatar
      Rick01
      Thanks. I forged ahead the day I sent this nessage and the new router is, in fact not "stupid". Configuration went flawlessly. Also my download speeds have increased from 15-20 Mbps to 40-60 Mbps. Your answer was spot on. So far I love this router!
