Fishbait58
Mar 03, 2021Follower
Nighthawk X6S AC4000 best t568a or t568b?
What is Nighthawk X6S best wired for a t568a or t568b?
1 Reply
It really doesn't matter.
They just wiring standards. Both ends of the cable are wired using the same standard. Even if you mix them up making your own cable, it creates a crossover cable which is what you used to use for directly connecting 2 pc's together without a router/switch.
