ja95606
Jan 19, 2018Guide
Nighthawk X6S AC4000 R8000P-Lose internet connection every other day
 From November 16, 2017 until today (Jan. 19, 2018) my Netgear router, model R8000P Nighthawk X6S Tri-band has lose internet connection every other day. To get it back I have to unplug the router, plu...
- Jan 28, 2018
Just an update on my lose internet connection isssues; as of Friday Jan 26, the Dlink router hasn't lost any connection at all. I've disabled the Dlink router, enabled the Netgear X6S R8000P router back in service, downgraded a previous version of the fimrware, and as of Friday afternoon (Jan 26) until the present Sunday Jan 28 at 12:30 AM, the Netgear hasn't lose connection either. The following gives instructions on how to download, the new firmware to your router. Do not upgrade using a wireless connection. Go to Netgear Support page; sign in; click on Download; enter he Product name or model number; Next page, right side Firmware/software; click on the down arrow "v"; and look for firmware V1.1.4.6
This is the version that's working for my router right now,wihout losing internet connections. Aslo keep in mind, this is for the Netgear X6S AC4000 model R8000P router.
jikamens
Jan 23, 2018Apprentice
This just started happening to me after upgrading the firmware in response to the security notification I received on January 18.
The upgrade brought me up to firmware version V1.3.0.8_1.2.1. In the four days since I've upgraded the firmware, I've had to power-cycle the router twice because my internet ground to a halt. Note that I power-cycled all other components of my network -- PC, switch, cable modem -- first, before power-cycling the router. None of that made a difference. It's clearly the router that is at fault.
There is clearly a bug in the new firmware version. Is Netgear aware of this? Are they working on a fix?
- ja95606Jan 24, 2018Guide
I've replaced the Netgear Nighthawk X6S AC4000 router with my old router (Dlink DIR-860L, Dual band) router, and believe it or not, I haven't had any problems (lose internet connections) since. It's been 4 days now without internet loses.
It's obvious that the lose is contributed to the Netgear router, and I believe it's in the firmware version. After a few more days, I'm going to try another test, and reconnect the Netgear router back up, and "download a downgrade version of the firmware to see what happens. This downgrade will be lower than the preinstalled version. We'll see!
- ja95606Jan 28, 2018Guide
- jikamensFeb 06, 2018Apprentice
I'm a little queasy about marking this issue "solved" when the workaround that solves it is to downgrade to an earlier firmware version -- which has known security holes in it that are fixed in the newer versions of the firmware.
Given that Netgear doesn't provide any ability whatsoever for end users to contact them without paying money for the privilege, there's no way for us users to report that the new firmware has a bug which is essentially making our routers unusable.
I would hope that there would be people from Netgear monitoring these forums and noticing these reports, but I'm not sure that's happening, and I'm worried that marking a forum posting "solved" will make it less likely that they'll notice it.
Am I mistaken. Is there some way I can report this bug to Netgear officially which doesn't require that I first pay them money for the privilege of being allowed to talk to them?
