ja95606
Jan 19, 2018Guide
Nighthawk X6S AC4000 R8000P-Lose internet connection every other day
 From November 16, 2017 until today (Jan. 19, 2018) my Netgear router, model R8000P Nighthawk X6S Tri-band has lose internet connection every other day. To get it back I have to unplug the router, plu...
- Jan 28, 2018
Just an update on my lose internet connection isssues; as of Friday Jan 26, the Dlink router hasn't lost any connection at all. I've disabled the Dlink router, enabled the Netgear X6S R8000P router back in service, downgraded a previous version of the fimrware, and as of Friday afternoon (Jan 26) until the present Sunday Jan 28 at 12:30 AM, the Netgear hasn't lose connection either. The following gives instructions on how to download, the new firmware to your router. Do not upgrade using a wireless connection. Go to Netgear Support page; sign in; click on Download; enter he Product name or model number; Next page, right side Firmware/software; click on the down arrow "v"; and look for firmware V1.1.4.6
This is the version that's working for my router right now,wihout losing internet connections. Aslo keep in mind, this is for the Netgear X6S AC4000 model R8000P router.
YungSynthlord
Jul 22, 2018Aspirant
Make sure you update the firmware. Theres a new firmware update. When you update you have to be hardwired to your router. The new update should fix your connection issue.
Zantetsukin
Jul 22, 2018Tutor
It is the latest, and did not resolve the issue, so I got rid of the issue all together and replaced it with another router, which works great, as it should. I honestly can't believe you are willing to sell defective products, and in the nearly 10 months it has been out you haven't fixed it.......
Thanks for not helping, and being useless.
- ZantetsukinJul 22, 2018TutorFyi, that second half was directed at Netgear, not you. Good luck!
