Graymin
Mar 06, 2020Aspirant
Nighthawk x6s ac4000 #R8000P
Ok just bought this thing setup was painless although the wifi cam I have just ouside my window 10 feet away lost signal but the ones in the house seem to do ok so far then S/N is in use and ...
- Mar 06, 2020
Good Morning,
Yes, probabaly wouldn't buy a router from Amazon. Was it "refurbished" or "renewed" as labatt mentioned? Unfortunately, even if listed as "new" we hear stores from many users who receive items which were clearly returned and resold.
Let's get the router reset and we can continue to try and help.
https://kb.netgear.com/25336/What-are-the-factory-default-settings-for-my-Nighthawk-X6-R8000-router
labatt
Mar 06, 2020Mentor
When you did the factory reset did you hold the button in for 10 seconds and see the lights start flashing. If not then you did not do a real reset. After a reset the default user ID and password should work. It is possible this has been out to someone else before you. It has been reported on here at times of folks getting a refurbished router or returned that was beening sold as new on Amazon. Do not know how true that is, as that does not sound like how they normally do business.
- shadowsportsMar 06, 2020Hero
Good Morning,
- GrayminMar 06, 2020Aspirant
ok got som sleep and tryed the reset again this time I held my mouth right :) it worked got in and updated things I still cant register it though but I got a e-mail to support have not heard back yet
