Baz_2106
Jul 31, 2021Follower
nighthawk X6S AC4000
Hi i installed my Router about 4 days ago but now because where it is i need to resite it into a better position so i can see the controls my question is if i unplug and move it to new sit not far aw...
michaelkenward
Aug 01, 2021Guru - Experienced User
As microchip8 says, it should work just fine, but this would be a good time to backup your router's settings.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual Manage the Router Configuration File.
