kngn
Jun 06, 2021Follower
Nighthawk X6s compatibility with Nighthawk X4s Dual band AC3200
Has anyone had any luck connecting the Nighthawk X4s AC3200 with the Nighthawk X6s - EX8000 extender? We haven't had much luck getting the x6s to work with our old Arris router and are thinking o...
Jun 07, 2021Guru - Experienced User
The EX8000 works pretty well. I've got one and I've connected it to an Arris SBG8300 before. It worked fine.
What actual issue are you having?
It might be worth trying to figure out whats going on before throwing hardware at the problem
