kngn
Jun 06, 2021Follower
Nighthawk X6s compatibility with Nighthawk X4s Dual band AC3200
Has anyone had any luck connecting the Nighthawk X4s AC3200 with the Nighthawk X6s - EX8000 extender? We haven't had much luck getting the x6s to work with our old Arris router and are thinking o...
michaelkenward
Jun 07, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
or, in the case of the EX8000, here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
