upnyakhir
Sep 05, 2023Follower
Nighthawk X6S Internet Issues
The internet light on my router is flickering white. I’ve seen that a blinking white light indicates that data is being transmitted or received, but this seems to be more a very fast flicker and do...
michaelkenward
Sep 07, 2023Guru - Experienced User
Which router do you own. Nighthawk X6S is more a marketing thing for its wifi technology than a model number – look at the label on it for that. Something like R8000P.
upnyakhir wrote:
The internet light on my router is flickering white. I’ve seen that a blinking white light indicates that data is being transmitted or received, but this seems to be more a very fast flicker and does look standard.
Very fast is what I'd expect. Sometimes so fast that it doesn't even seem to flicker.
My modem is running fine but my internal is currently down. I’ve tried restarting my router then both my router and modem, but no luck. I’ve switched Ethernet cables and the issue continues.
What is that modem?
I assume that you mean Internet is down rather than your internal network. Is that wired connections? Wifi? Everything?
What happens when you try to connect things? Any error messages?
Did you do all that in the right order?
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
