KmKl
Dec 08, 2023Aspirant
Nighthawk X6S low wifi output
Aloha,
I have a Nighthawk X6S and just upgraded my cable modem to run at 500 Mbps. Then I do a speed test I am only getting 90 Mbps through Wi-Fi sitting next to the router. When I log into the...
Dec 08, 2023Guru - Experienced User
What model router do you have? X6S isn't a model #. R####?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What devices are connected to the router and what devices are you using to speed test with?
What channel configurations are currently set on the router?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
KmKl
Aloha FURRYe38,
I will get the information and try your recommendations when I get home.
Thank you for the quick response.
Thanks and Aloha
