syntax's avatar
syntax
Nighthawk x6s question
I was thinking buy the nighthawk x6s but does anyone have prob with firmware?  What are the speed you get on here I have charter 400mbps and 20 uploads?
1 Reply
  • plemans's avatar
    Are you referring to the R8000P router (since you posted in the router forum)
    Or the EX8000 extender? (since thats what you put in your signature)
