dandrus6
Oct 25, 2021Aspirant
Nighthawk X6s R7900P - Not able to update the router with the App.
Nighthawk X6s R7900P - Not able to update the router with the App. I have moved and have a new internet provider. Router works but doesnt seem to be working at its best
- Oct 26, 2021
Thank you for the help. That worked.
dandrus6
Oct 26, 2021Aspirant
- FURRYe38Oct 26, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
