ghoulie27
Jun 01, 2023Initiate
Nighthawk X6S R7900P authentication email incorrect.
I have a Nighthawk X6S R7900P and the authentication email displays the wrong email. My free support has ended and I cannot find anywhere to change the email to the correct email.
Steve
Thank you. I chatted support and while chatting I did the following: In the Nighthawk app, I disabled two-step authentication, logged out, logged back in and then enabled two-step authentication. I logged out and then back in and it did show the correct email in the two-step authentication process. Also, support refreshed my email on their end.
Try logging into your NG profile account and change email addressing here?
If not, you'll need to contact NG support and ask them to help you with this.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/- ghoulie27Initiate
Thanks for the process. Glad you got it working.
Enjoy. 📡
Email for what?
