Pasture
Sep 09, 2020Tutor
Nighthawk x6s R7900P router failure to update GUI language file
Hello, I am unable to update my firmware from 1.4.1.42 because I get a message "FAILED TO UPDATE GUI LANGUAGE FILE". I have a Nighthawk router R7900P. Please HELP
- Sep 10, 2020
Plemans,
Thank you sooooo much for your assistance. I was able to update my router to the latest version, thanks to your kind assistance.
Yesterday was my 59th wedding anniversity and you provided the " second best gift " :-) .
Thanks again,
Frank Craig
Sep 10, 2020Guru - Experienced User
Manually means you download the actual firmware file, extract it, and then log into the router and manually update it.
fairly easy to do. Instead of letting the router search, in the same section of the router you click on browser and upload the firmware to it.
Pasture
Sep 10, 2020Tutor
Plemans,
Thanks again,
Frank Craig
- plemansSep 10, 2020Guru - Experienced User
Glad to hear you got it working!
