KB7GP
Nov 20, 2024Aspirant
Nighthawk x6s R7900P
My home network consists of a Comcast System One Modem/Router. My desktop and printer each plug into one of the Ethernet ports on the back. I have a long Ethernet cable into another port which runs to...
KB7GP
Will the Netgear match the identical SSID as the Comcast modem/router?
Dave Robinson
Nov 21, 2024Guru - Experienced User
yes and no.
Here's why I say that.
You can manually set them with the same ssid. But they won't roam the same as a mesh system will because they don't integrate like a mesh with smart roaming enabled.
So would I set them the same? No.
I'd set them with separate ssids and make sure they use different wifi channels to prevent interference.
