DJB628
Dec 16, 2022Aspirant
Nighthawk X6S R7960P From Costco
My router is an X6S R7960P purchased from Costco ans currently up to date with the latest firmware.
I have 2 Fire sticks that I assigned a reserved IP, then I decided to swap the locations of the FS, and renamed them on the Amazon website, but I guess once doing that they were assigned new IP's when I moved them around.
So when I went into the router admin section to delete the 2 assigned devices and re add them to be assigned to the new IP addresses, I keep getting an error MAC ID incorrect.
Any suggestions how to resolve this ??
Don
I have no idea what a A65 is. do you have an actual model number?
(ac3600 is a speed)
Why are you setting them with a static ip address?
You went in and deleted their address in the router?
- DJB628Aspirant
Sorry, it was the info showed when I logged in
It's a Nighthawk X6X (R7960P)
The reason for assigning an IP, is i often got conflicting IP's addresses in the past, so I have since reserved and assigned IP addresses to devices I use often and have to login into at time to transfer files.
And yes, I went to my assigned IP section and simply deleted the 2 FS that were assigned, and then tried to reassign them with the current IP's and same MAC which didn't change
If it's not required, then I'll leave it as is.
- DJB628Aspirant
Typo in last post, Model is Nighthawk X6S R7960P
If a Mod can edit the first post title and body of post it would be greatly appreciated, it doesn't allow me to do so.
