Dfixit1
Feb 13, 2023Aspirant
Nighthawk X6S R7960P Mac Error Firmware Version 1.4.4.94 Bug Fix
Got tired of the Netgear delay in fixing the firmware bug, when you try to assign IP addresses on the LAN (Mac error), so today I reverted to the previous version firmware. If you go to the firmware ...
Dfixit1
Feb 14, 2023Aspirant
- Dfixit1Feb 14, 2023Aspirant
“Worked like a champ and didn’t have to beg for an untested beta fix that was in another post.”
Why hasn’t Netgear addressed this ASAP? Beta fix? I’ve been a beta tester and not sure if I want to run my WiFi with beta firmware……thanks.
- FURRYe38Feb 14, 2023Guru - Experienced User
NG has addressed it. Works for others.
Good luck then.
