Erikrm
Jun 07, 2018Guide
Nighthawk X6S R8000P AC4000 USB Disk no more available since upgrade to 1.4.0.10_1.2.14
Hello,
Since the last firmware upgrade I made 3 days ago to firmware version 1.4.0.10_1.2.14 the external USB disk is no more available/shown in the ReadySHARE Storage interface.
The external USB...
- Aug 11, 2018
Hello,
Netgear finally made a new firmware that is working just perfectly!
All previous issues have been solved.
Firmware Version V1.4.1.24_1.2.20
GUI Language Version V1.4.1.24_2.1.46.1
Very good, but next time please make more tests before releasing new firmware versions.
Erikrm
Jun 07, 2018Guide
Hello again,
The only I found so far, has been to downgrade to the previous firmware version 1.3.0.10_1.2.2 and the external USB disk is working fine again.
I hope Netgear will make corrections with a new and better firmware update.
- bmzeroJun 07, 2018Aspirant
Same issue for me. My USB drive is a 8TB My Book.
Downgrading the firmware fixed the issue for me as well.
- ErikrmJun 08, 2018Guide
Hello bmzero,
Do you use the Access Control on the router?
If yes, did you have issues with this function you too? (I created another discussion about that)
I hope Netgear will soon find a solution for those issues.
- bmzeroJun 08, 2018Aspirant
I do not. For my needs, the older firmware should be fine. I'll try the next one that comes out. Good luck with your issues.
