JJMAN1st
Aug 08, 2022Aspirant
Nighthawk X6S R8000P LAN Ports do not work.
Howdy folks. I have the R8000p Router. I came home on Sunday to no internet at all. After some extensive troubleshooting I noticed that neither the LAN ports or Internet Lan Port work at all. The...
Aug 08, 2022Guru - Experienced User
Have you disconnected the router from everything and pulled the power adapter for 1 good minute or more then connect one wired PC to the back of the router then plug back in and see if anything appears on the LAN LEDs on top? I presume if nothing appears and you have swapped LAN cables as well that the router is faulty and needs replacing.
JJMAN1st
Yes I have pulled if off the wall and its set for many minutes a few times to discharge. I have already tried that and no lights light up for lan at all. All 4 Lans and the Internet jack also. All the lights work for the power, wifi's and all that. And it was just sudden. Worked the night before and I have had it for barely over a year and then just out of the blue, no power to the ports. I didnt know if someone on here might
know something about this or not. Maybe a fix or trick that I hadnt thought of.
I appreciate your reply.
- FURRYe38Aug 08, 2022Guru - Experienced User
Ok. Sounds like it needs replacing then. Sorry about that. đŁ
