Hdowell1208
Aug 23, 2022Follower
Nighthawk x6s r8000p problem
So this happened and I haven’t messed with it but 2 times in the past 7 months. All the wires are good and all the lights are on and I can connect to the router with any device and it says it’s conne...
michaelkenward
Aug 24, 2022Guru - Experienced User
Hdowell1208 wrote:
All the wires are good and all the lights are on and I can connect to the router with any device and it says it’s connect but I don’t get actually connected
What says connected?
What doesn't get connected to what?
Does your router get an Internet connection?
Is this wifi stuff or wired devices?
Is it just a wifi app that causes you grief?
Can you login to the router with the browser graphical user interface (GUI)?
