warhawk
Jun 16, 2021Aspirant
Nighthawk X6S R8000P WiFi Performance
Hello. I recently upgraded to Spectrum 1gig internet service and have noticed that my WiFi speeds aren't quite what i'd hoped and speed tests average 600mb/s. I've ran tests on multiple devices usi...
- Jun 16, 2021
I don't think its a "culprit" issue.
I'd recommend reading 2 articles.
One on an actual tested speed of the device.
NETGEAR R8000P Nighthawk X6S Tri-Band WiFi Router with MU-MIMO Reviewed - SmallNetBuilder
The other is on wireless misunderstandings.
Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
I'd highly recommend reading through both to get realistic expectations of wireless and why. Both are well written and very informative both on your device and wireless expectations.
Jun 16, 2021Guru - Experienced User
so let me get this correct, you're getting 600mbps out of the R8000P?
Is that correct from what you've said?
And what device are you testing it on?
warhawk
Yes that is correct and that speed is over WiFi.. I’ve used both an iPhone and laptop to test speeds. I’ve also confirmed the network card in the laptop is capable of these speeds so that is not the culprit either.
