Ahmed_225
May 10, 2022Aspirant
Nighthawk X6S SSID Broadcast Not Showing Up
I tried to do everything by resetting my router, changing my power adapter, downgraded and upgraded the firmware I even have checked mark the SSID so many times. However, my router doesn't show the wi...
Ahmed_225
Yes I did
May 10, 2022Guru - Experienced User
Not a good sign if the wifi on/off button doesn't work and neither does a factory reset.
Is it still in warranty?
- Ahmed_225May 10, 2022AspirantUnfortunately, no.
- plemansMay 10, 2022Guru - Experienced User
In my experience, usually 1 band dies and then the others.
Have you tried disabling smart connect?
I think there might even be a few 3rd party firmwares for that router. Might be worth a shot
- Ahmed_225May 10, 2022AspirantAs I thought, it seems that there is no way to fix it as a firmware. Ok then, would you mind sending me a link for the 3rd party firmwares?
