Krislafreniere
Mar 26, 2021Tutor
Nighthawk X6S will not update firmware
Tried every way to ugrade firmware on my X6S. Nothing works. I have heard that the only option is to get an RMA. I am asking Netgear to step up and solve this issue for once and for all.
You'd want to contact support. These are the community support forums where members of the public try to help out.
We're not netgear.
Click on "mynetgear" at the top. register an account and the device. From there you can contact support.
- Bluetyler63Aspirant
Yes, having the exact same problem. Tried using the app, then the login page and finally downloaded the firmware and tried to update over ethernet. Nothing works. Very frustrating. Is there any solution to this?
