Orms462
Nov 25, 2021Aspirant
NIGHTHAWK X6S
Latest Firmware failed! Now my App asks me to sign in as admin but wont accept password which i know is right! When going through process as forgot password, security questions answers are reported...
- Nov 25, 2021
Security question are buggy for a long time, ie they don't work as advertised. At the back of the router there's a reset button. Press it for 7-10 minutes (or until Power LED begins to flash) then release. This should perform a factory reset
microchip8
Nov 25, 2021Master
- FURRYe38Nov 26, 2021Guru - Experienced User
I would think 7-10 seconds is long enough for a reset to be triggered.
- Orms462Nov 26, 2021AspirantThanks but doesn’t reset admin password! I have now reset it doing it on a Pc running Chrome.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - michaelkenwardNov 27, 2021Guru - Experienced User
Orms462 wrote:
Thanks but doesn’t reset admin password! I have now reset it doing it on a Pc running Chrome.If the reset button did not restore the admin password to is default, then either your router has a more serious issue or you were doing something wrong.
Using the browser graphical user interface is actually a less reliable move than the physical button.
The key is to press the button with the power on, and for at least 10 seconds, until the key LEDs on the front start flashing. This is something that people sometimes overlook.
