RajunCajun9
Jul 02, 2022Aspirant
Nighthawk X8 / Netgear Genie download
I have a new Desktop with Windows 11 and i cannot get Netgear Genie for Windows to download at all! Is there another way to download it on my desktop? What am I missing, all this setup and software...
Jul 02, 2022Guru - Experienced User
Why not just access it using its IP address?
michaelkenward
Jul 03, 2022Guru - Experienced User
You should check out the program. It does things that you can't do in the GUI. I use it all the time.
