Courtshier
Oct 31, 2021Aspirant
Nighthawk X8 extender
Hello. I purchased a nighthawk x8 extender and it won’t set up in the app. It doesn’t connect no matter what I do. I have reset it. Done everything. Any advice?
Oct 31, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
I would review the user manual and installation guide to to see if this helps as well.
Thank you.
