PRInt
Dec 02, 2016Aspirant
Nighthawk X8 R8500 - wifi problems
Ok so this is my 4th R8500 router - 1 of them I have successfully working and it is great. Of the other 3, all of them have come with a wifi issues, out of the box the "first" 5ghz network will not w...
- Jan 17, 2017
Hey. Thanks for the reply. We have nothing like that near us. In the end I went through 5 of the R8500 all of them had some sort of transmission issue. In the end I am sad to say I switched to a linksys and it has worked perfectly. I do have an R8500 at home which works flawlessly. I am guessing it was just a bad batch!
William10a
Jan 16, 2017Master
What type of warehouse and what is around your location any cell phone towers, radars, or electronic transmitters even the r7500 x4s has the 160mhz channel band witdh an radar from a ship or airport will make the channels open to x4s series close these new channel making just normal x4 router.
PRInt
Jan 17, 2017Aspirant
- ElaineMJan 18, 2017NETGEAR Employee Retired
Can you compare the Serial Numbers of the one that you own versus the one that you're troubleshooting?
