leugaanam
Jun 22, 2017Aspirant
Nighthawk X8 R8500 ethernet port not recognized after firmware update
My Netgear Genie says that there is no ethernet cable hooked up to the main ethernet port. It suggested trying different cables or reconfiguring the port. I have tried several different cables; all w...
- Jun 28, 2017
james2720502 Thank you for responding but moreover, thank you for actually reading what I wrote. I ended up paying an IT site to help me. And wouldn't you know it, they had the problem solved within 10 minutes. Oddly enough, they asked the same questions you have and it lead to a solution. Again, thank you for asking valid, pertinent questions; instead of giving me attitude like "netwrks" did.
netwrks
Jun 22, 2017Master
Hopefully, you let the router finish the firmware upgrade.. Follow the Reset to Factory Default instructions on the top of Page 182 of the router manual.
