Dr_Dan
Sep 03, 2017Aspirant
Nighthawk X8 R8500 Rattle - How to Open Box
My router is working fine, but when I picked it up and moved it I noticed a rattle. I think something small may have fallen into the box. I found 2 obvious hex screws on the bottom, but I'm sure I m...
- Sep 06, 2017
There are more screws on the feet.
Remove the rubber feet in each corner and you'll see more screws.
TheEther
Sep 03, 2017Guru
You can find videos on Youtube. Search for "R8500 disassembly".
- Dr_DanSep 03, 2017Aspirant
I already looked there. I found a video for the x6, but it's a different box and doesn't apply.
- doraemonSep 06, 2017Prodigy
- Dr_DanSep 06, 2017Aspirant
Thanks, that did the trick! It turned out to be a little piece of black plastic that had broken off something.
For anyone trying to accomplish this, you can pry off the rubber feet with a screwdriver. If you're careful, you can just pry up half and bend it back enough to remove the screw without taking the pad off completely, making it a little easier to just stick back on.
