Dr_Dan's avatar
Dr_Dan
Nighthawk X8 R8500 Rattle - How to Open Box
My router is working fine, but when I picked it up and moved it I noticed a rattle. I think something small may have fallen into the box. I found 2  obvious hex screws on the bottom, but I'm sure I m...
  • doraemon's avatar
    doraemon
    Sep 06, 2017
    There are more screws on the feet.
    Remove the rubber feet in each corner and you'll see more screws.
