Lorisworld's avatar
Lorisworld
Nighthawk x8 router
My Nighthawk x8 does not have a telephone port. What adapter do I need to attach a landline?
  • plemans's avatar
    Jul 20, 2024
    Lorisworld wrote:
    Thank you for the reply. I am transferring a landline from AT&T to xfinity.----what modem/gateway do you have? They told me I could just plug it in. Technical support there is terrible. I will probably cancel xfinity and get ooma----You still need internet service to use Ooma. . Thanks again.
