Lorisworld
Jul 19, 2024Aspirant
Nighthawk x8 router
My Nighthawk x8 does not have a telephone port. What adapter do I need to attach a landline?
- Jul 20, 2024
Lorisworld wrote:
Thank you for the reply. I am transferring a landline from AT&T to xfinity.----what modem/gateway do you have? They told me I could just plug it in. Technical support there is terrible. I will probably cancel xfinity and get ooma----You still need internet service to use Ooma. . Thanks again.
Lorisworld
Jul 20, 2024Aspirant
Thank you for the reply. I am transferring a landline from AT&T to xfinity. They told me I could just plug it in. Technical support there is terrible. I will probably cancel xfinity and get ooma. Thanks again.
Jul 20, 2024Guru - Experienced User
