Tony-Aus
Sep 10, 2020Aspirant
NIGHTHAWK X8 SEARCHING FOR ETHERNET CABLE WHEN TRYING TO CONNECT TO VDSL (Aus - iiNet)
The X8 has the latest Firmware. Windows 10 updates to date. ISP is iiNet. Internet connection is Fibre to the Node (VDSL). Connection for VDSL, internet service, is via a phone connector Not Ethe...
- Sep 10, 2020
Thank you antinode (Sage), I realise now the article refers to the D8500. I'll pick op a DM200 which will allow me to connect.
Well done and Thank you.
Tony-Aus
The actual error reads:
No Ethernet Cable Is Plugged into the Router Internet Port
I have also discovered the missing setting is:
"TRANSFER MODE" which should equal "VDSL(PTM)"
Thanks for the respone antinode (Sage). I agree, it appears I would need a VDSL modem however there are settings in this unit that allow for setting up an internet connection which include username password etc. of course via Ethernet.
The following article which demonstrates, roughly in paragraph three, and I quote "The Nighthawk X8 provides a built-in fast DSL modem for broadband that is compatible with legacy ADSL, ADSL2 and ADSL2+ connections as well as lightning-fast VDSL and VDSL2 speeds"
I have also requested assistance from Netgear Support to see what they come back with however welcome all posts for an in-depth understanding.
Tony-Aus
