d0x
Jan 20, 2022Guide
Nighthawk xr1000 Duma errors (multiple)
I just bought an XR1000 yesterday and I was setting it up and after I was done and the firmware was updated I started getting some errors and I was also unable to enable upnp which was disabled by def...
Jan 20, 2022Guru - Experienced User
this is one of those times that you'll get better help posting in the proper foum.
You're in the standard router forum versus the pro-gaming one that runs dumaOS.
The guys on there are super active and involved. I'd start there.
d0x
Jan 20, 2022Guide
I figured. I tried to post there but when I typed my model# it couldn't find it. Then a few min ago I registered my serial# and now it shows up... Sigh
I'm actually making the new topic now.
- plemansJan 20, 2022Guru - Experienced User
Hope it works well. the guys on there are great to work with and help out.
