Capwifi
Dec 08, 2020Aspirant
Nighthawk XR300 showing connection to internet but nothing loads
We just bought this router and connected it to another via Ethernet. It worked for a few minutes but then stopped. The router is showing full wifi connection and so is my phone but nothing will load. ...
- Dec 08, 2020
What other router do you have it connected to?
Running 2 routers in router mode causes a double nat and can cause issues.
https://kb.netgear.com/30186/What-is-Double-NAT
You can put one in access point mode. so:
Modem-----router (in router mode)------router (in access point mode)
Capwifi
For clarification we are trying to use this router as a booster for our original router via Ethernet.
- plemansDec 08, 2020Guru - Experienced User
