efire9207's avatar
efire9207
NightHawk
I had the Nighthawk x6, my ISP is a local Fiber connection. Usually, once a week I lost my Internet connection. the light would be amber and the genie would say Internet Not Connected.  One of the te...
  • efire9207's avatar
    efire9207
    Aug 28, 2017
    it wasn't totally disconnected... the light was still on. just couldn't connect... so I went to the Advanced page of Internet Settings and changed the Mac Address to Use Computer Mac Address.. that worked for a while.. then lost connection again.  Went back there and change to Use this Mac Address and so far it's been a week and a half and it's still running
