BigDaddyDoDah
Apr 17, 2021Aspirant
Nighthawk
I just bought this and can not get connected to the internet. I keep getting "Ethernet Not Connected".
michaelkenward
Apr 18, 2021Guru - Experienced User
Bought what? A Netgear router? Which one?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
You may have done this already. I can't tell from your message.
BigDaddyDoDah
Apr 18, 2021Aspirant
Yes I have followed insructions well but continually recieve "ethernet not connected".
- michaelkenwardApr 18, 2021Guru - Experienced User
We still do not know what you are trying to install. Nor do we know anything about what you are trying to do.
Your subject now says "Nighthawk AC 1750 WI-FI ROUTER". That is an improvement from the original "Nighthawk". But it still doesn't tell us what you have bought or what you are doing.
Have you bought a new router? You want to add it to your network?
What do you have there already? A modem of some sort?
AC1750 is not a reliable guide to the model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Did you follow any of the suggestions in my previous response?
If you need more help, then we need more details.
