Beep01
Jun 03, 2021Follower
Nighthawk
Hello Community;
I have a Nighthawk X6 AC3200 wireless router, I would like to change the names on some of my attached devices to make it more convenient to look them up for example the ip address.
I found the basic instructions on line, BUT, it said to click on the EDIT tab. On closeer looking all over the ADVANCED page I was not able to locate the EDIT tab, can you help with this problem ??.
Thanks for your help
Beep01
1 Reply
- DarrenMSr. NETGEAR Moderator
Have you tried to do this on the Nighthawk App?
DarrenM
