MRSISTER
Jul 17, 2021Aspirant
nighthawk
have a 7000..i have 400 mbps...but only getting 115mbps when i test?
MRSISTER
R7000
Firmware Version
V1.0.9.88_10.2.88
spectrum modem 400mpbs
hardwired 2.4g
tested 2 laptops and 1 pc
spectrum speed test
Portwey84
Jul 18, 2021Virtuoso
Ok, I am trying to help here, but you've still not said which actual model of R7000 you have so I'm going to assume by the firmware version you've quoted, that you have the R7000 AC1900 model.
I can already see by the firmware version you have quoted, that you are 5 firmware updates behind the latest Hotfix release, so you might want to try updating your firmware first. Do yourself a favour, DON'T do it over WiFi, do it via ethernet and follow the release note instructions for updating the firmware.
