Easypeasy5
Jan 20, 2022Aspirant
Nighthawk
Hi there. First question so hopefully in the right place! Router is working ok but yesterday it was showing connected but no internet. I was using it in my van with outside antenna. It was in a secluded/ hard area for reception but if it's showing signal is there anything else I can check? Thanks
Move to a different location.
Power off the router and back ON.Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you - michaelkenwardGuru - Experienced User
What was showing that? The router? An attached wifi device?
- Easypeasy5AspirantHi. I meant the router was showing devices connected to router. Also router was showing signal was there as well on router. Devices connected but no Internet. I was using outside antenna connected
Easypeasy5 wrote:
Devices connected but no Internet. I was using outside antenna connectedI am still none the wiser.
I asked because a common issue is that a device can happily connect to the wifi from the router and the router can be connected to the Internet, but something on the device is blocking that from getting on to the router. It will then show the "no Internet" warning. This is pretty common on PCs where the Windows tried to protect the local network from nasty things in the outside world. Sadly, those "nasty things" can be the Internet.
I see no sign that you have followed the advice from FURRYe38 and asked for help in the right section for your hardware.
Some issues are generic to all routers, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
Maybe someone there will understand what you are saying.
