BossTrout
Jul 23, 2022Aspirant
Nighthawk
I recently got a nighthawk from someone to use for my WIFI because i didn't want to rent a router from the company. For some reason it doesnt put out the mbps that im paying for so i dont know whats ...
BossTrout
Sorry i should've put it.
R7000P
Firmware:V1.3.1.64
i dont know the modem one its the one they gave me probably the 2022 version one
everything is wired (except my phone but still shows same speed on everything)
i pay for 500mps i get around 240 up and down
michaelkenward
Jul 24, 2022Guru - Experienced User
Most modems have a label on them. Without knowing what the modem/gateway is that connects you to the Internet it is anybody's guess as to what might be happening on your network.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
As this is a second hand device, your first move should be to "factory reset" the thing.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
