Rusty71
Aug 29, 2022Follower
Nighthawk
Received notice of firmware update. Will not download or install
What model device do you have?
What firmware are you on?
You can manually update it.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with. - michaelkenwardGuru - Experienced User
To add to what plemans suggests:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
