Danne_V's avatar
Danne_V
NighthawkNighthawk X6 R8000. Are router blocking elements?
Running a private site at a webhost. Have the same on local server (my computer). Have added a facebook feed generated by curator.io, When opening the page with the links and insert from my own computer, it's fine. When others opening the same page via their own internet providers, the facebook feed shows.
But when I open the same page from webhost (via interentsupplier and my router) the facebook feed is dead.
Go to https://test.karlstadsak.se and scroll down a bit. Can you see facebook posts? I can't (even if can see them without problems when opening the exact same files from the server in my computer.)
I'm probably a dimwit when it comes to this. But I've made websites the past 25 years and have never encountered an issue like this. So, I figure it's either my internet supplier och my router who's blocking.
Can you help?
Cheers,
Dan
1 Reply
  • FURRYe38's avatar
    Happens with different browsers or a different PC?
    Be sure to clear out all browser caches.
    Try using some different DNS services on the router, like cloudfare or quad9.
    Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
