aiaf1
Apr 20, 2022Follower
NighthawkNighthawk X6 R8000 firmware V1.0.4.84_10.1.84
Just let router update to latest firmware. V1.0.4.84_10.1.84
restart etc as per normal.
now the second 5GHz-2 is no longer available.
All setting correct, but no longer broadcasts.
Worked before the update. Firmware bug.
Have tried all the frequency to no change in outcome.
1 Reply
Did you try a factory reset?
Does it show as disabled in the gui browser?
Are you using smart connect?
