FlicherDK
Apr 11, 2022Aspirant
Nighthawk(R) X4S R7800 - Can't Open Port 1935
Hi there I'm having problem with port forwarding on my router. The port im trying to port forward is port 1935 on my local ip. I can forward port 10823 used for multiplayer server in farming s...
DexterJB
Apr 21, 2022NETGEAR Moderator
Hi FlicherDK, welcome to the community! We'd like to know the following.
How are you checking if the ports were successfully forwarded? What results are you getting?
Do you have UPnP enabled?
Has it worked before?
Have you tried any other firmware versions?
Dexter
NETGEAR Team
- FlicherDKApr 21, 2022Aspirant
How are you checking if the ports were successfully forwarded? What results are you getting? - is there away to test the port? - I only tried the stream the RTMP server that used that port and can't connect
Do you have UPnP enabled? Yes
Has it worked before? - No, but i can open port to a game (Farming Simulator 22)
Have you tried any other firmware versions? With the one when i uptatede when i got the router a year ago.
