cutthr0at
Mar 14, 2021Aspirant
Nighthawk(R) X4S R7800 5g Wifi keeps disconnecting
Hello, My Nighthawk(R) X4S R7800 is disconnecting 5g wifi on all devices (2.4 works without an issue) all the time and its getting very annoying. My firmware version is V1.0.2.80. Its happening ...
Mar 15, 2021Guru - Experienced User
I don't have an R7800 but from the forums, its seemed like theres been a few people with issues on the newer versions of the firmware.
Try version 1.0.2.60. Then do a factory reset and new install (don't use a backup). See how that works.
- cutthr0atMar 16, 2021Aspirant
It worked - kind of. 5G Network is no longer vanishing, only stops working. My laptop and all devices are connected to it but there is no networking, local and internet networks are inacessible. Everything works fine on 2.4. I'm thinking of downloading even older firmware and try as this router worked superb for past few years.
Thank You for suggestions
- plemansMar 16, 2021Guru - Experienced User
You can try older versions but that specific one was pretty stable. Did you do a factory reset and then clean install after the firmware change (by clean i mean not reinstalling from a backup configuration)?
It might be a hardware failure. How old is the device?
- cutthr0atMar 22, 2021Aspirant
Ok, i think i managed to resolve the problem. I belive issue was caused by incorrect PSU, instead of 12V, 3.5A i was using 12V 1.5A. I bought 12V 5A and it seems to be stable now. Im still loosing internet connection from time to time but WiFi have stopped disconnecting.
1464 packets transmitted, 1430 received, +7 errors, 2.3224% packet loss, time 1482484ms
rtt min/avg/max/mdev = 52.900/65.949/1838.384/79.937 ms, pipe 3
