DalGoda
Mar 12, 2019Aspirant
Nighthawk(R) X4S R7800 Compatibility Question (Orbi)
I have probably made a terrible mistake. I have a Nighthawk(R) X4S R7800 that I am very happy with. I was told that I could connect an Orbi "mesh" system to it, to expand my coverage. Seemed to simp...
- Mar 12, 2019Did you switch the orbi to access point mode? I've had mine in app mode hardwired to a c7800 without issues. 3 satellites connected without problems.
Mar 12, 2019Guru - Experienced User
And once it's in AP mode, use the orbi app to control it.
