PowerHouse99's avatar
PowerHouse99
Nighthawk(R) X4S R7800 Dynamic DNS not working
I use to use DYNDNS for my DDNS for years without issue. I switched to NOIP because it was cheaper and also free for Netgear. When I select this, I get [Dynamic DNS] host name registeration successful, registeration failure netgear in the logs. Yes.spelled wrong also. I tired reflashing the router. Reset back to defaults. Use a Mynetgear DDNS name and switched to NoIP - DDNS.NET with no help. At my wits end. There is a bug somewhere. I worked with NOIP and they said to tell Netgear to update the firmware. Anyone find a resolution? Thanks. I am using firmware v1.-.2.62 which is the latest.
  • PowerHouse99's avatar
    PowerHouse99
    Apr 30, 2019
    Pretty fustrating that there is no way to even inform Netgear of a bug in their firmware. Wow. Maybe take a cue from Microsoft and Andriod support. Your user base discovers the bugs for you. Why ignore your biggest asset? Even NOIP says to inform Netgear of the issue but there is just no way to do so without paying $89.00 for a support fee. I'll pay for $44 for the discounted DYNDNS instead of the $21 NOIP just to get it to work. I know one thing I won't be supporting.
  • Also, the first time you enter the DDNS info, it sends correctly and sets the IP. The issue is it never updates again.
      PowerHouse99
